Another Roto Baler Question
Jim Calhoun
10-15-2007 23:02:18
I have found an old roto baler and bought it. I own 2 white tops made in the 1970's and 3 older model orange tops. The baler I found is actually in great condition for sitting outside for years. It needs new belts and I will replace the press roller with one less deteriorated, but this baler shows little to no wear from use and it is not rusted up or frozen up.
It is different from all the ones I own, and due to fewer parts in the design, I suspect it to be much older. It has only one rubber v belt, the rest is either chain driven or gear to gear mesh.
It does not have the upper triangular roller that spins above the press roller, which is nice because that triangular piece only comes in handy when you are baling windrows that are too big for the baler anyway. Mostly this roller frustrates me because I cannor see the press roller to see if I am wrapping twine.
What year of baler's didn't have the upper triangular roller?
