WD45 air cleaner and carb
TWJanak
10-12-2007 17:51:18
If I put a WD45 crank in my WD with the power crater pistons, etc., do I necessarily need the 45 carb and intake? I would like the increased power but want to appear WD stock on the outside. Is this possible or even worth the trouble? Trying to figure out how I'm going to go with this rebuild when I actually get to it.
Thanks,
Travis
Aaron SEIA
10-14-2007 05:44:44
 Re: WD45 air cleaner and carb in reply to TWJanak, 10-12-2007 17:51:18
Mine is also a 12v system. Got a generator off of D17, I think (dad got it for me). Looks 100% like the 6v one. I've read you can also run an 8v battery on a 6v system for better starting. I think a good 6v with a mag and BIG battery cables would do ok. Problem comes with small cables and a dist.
Aaron SEIA
TWJanak
10-13-2007 18:07:33
Thanks Aaron. I guess it really doesn't matter since I plan on leaving the 12V system on. The tractor will be used regularly so I don't want to mess with 6V. So it wouldn't be all original anyways. Our blackland is hard to pull an offset through so I think the extra power would help. We'll see...
Thanks
Aaron SEIA
10-13-2007 17:36:13
What are your plans for the tractor? I doubt that you, or most others who make a WD into a WD45 would ever notice the HP difference in the first place. Parade machine or snow pusher won't make any difference. If you really want to work it plowing or something, then I would think you'll need the extra volume of the carb and intake to make the HP. You'd have 12% more cubes that will need to breath. My WD is now 100% WD45 from crank to intake. Ran it a long time on a WD intake, didn't know it had a 45 carb. My WC loader has a WD45 carb. Found out when I put a WD intake on it and it didn't fit. Short version of all this is, only the correct police will know the difference.
Aaron SEIA
