Need a complete carb rebuild kit
rkr29kracing
10-11-2007 17:38:16
Hello All
I have a carb off of a B that I am rebuilding. The disc numbers are 206989 and 8561C. However, I can't seem to find a complete rebuild kit number for this carb. thecarburatorshop.com shows 61AJ7, but I have not had any luck looking up this part number either. Anyone know what I need and where I can get it? I need a kit that includes the main jet and the discharge jet.
A big thanks in advance!
Steve in NJ
10-16-2007 04:22:43
 Re: Need a complete carb rebuild kit in reply to rkr29kracing, 10-11-2007 17:38:16
We service, repair, rebuild and sell parts & kits for the Zenith and Marvel Schebler carbs. The best way to clean these particular cast iron carbs is with Glassbeading. Rust and debris collect in the bottom of these carbs mainly because all the early versions were cast iron. Condensation and water in fuel drops to the bottom, starts rust and eventually plugs the enrichment circuits in the bottom of these carbs making the tractor run lousy. Glassbeading these carbs in and out gets the rust and debris out of the bottom passages, to make these carbs perform like new again. Drop us a line or give us a call if you need any help or info. Be glad to help out. Steve@B&B
rkr29kracing
10-12-2007 07:22:24
yeah, looks like someone drilled out the main jet, which is why I need a new one. The discharge jet looks like someone tried to removed it with a pair of plier, it is basically crimped closed.
I have had no problem getting the old parts out and the carb body cleaned up real well.
Where can I but these individual parts, and how do I know they will fit my carb?
Thanks.
Jim Moorhead
10-12-2007 15:11:54
 Re: Need a complete carb rebuild kit in reply to rkr29kracing, 10-12-2007 07:22:24
Value Bilt Tractor Parts in Indianola, Iowa may have those carb. kits.
DARDAN
10-11-2007 22:40:18
Usualy, you will need a kit that contains: inlet needle and seat, gaskets and seal rings. Somtimes a new throttle shaft and choke shaft. It takes a pretty rough carb to neeed more. I have found that Castrol super clean does a good job of cleaning the old crud and varnish(but not rust) off these old carbs. Similar to Right Stuff, or Advance Auto Part's Purple Power. Will even clean the green off of brass, but too chemicaly aggresive for aluminum.
For the rust removal, have the dissasembled body bead blasted. When washed up, clean, and dry spray paint carb inside and out with LACQUER paint, to prevent further rusting.
old
10-11-2007 21:32:03
A kit like you want isn't out there or I have yet to find one. You need to buy a kit and then the others parts on the side. But most of the time you don't need new jets because they last longer then you do as in they never wear out unless some one has drilled them out etc.
