TRACTOR LUBRICATION on D17
MONGO66
10-10-2007 08:07:06
Can anyone give advice on using the correct lubricating oils for my D17, I bought it used and I ended up having to replace a housing with rods and barrings that were not lubricated properly by the last owner.. Id prefer to do things right and I dont want this problem to reoccur..I have read that there are 3 areas on the D17 that need oil, one under the hood, and two right below the seat. What types of oil ( viscosities ) are people using? Is there a difference in straight engine oil vs transmission oil for that D17?? I use my tractor both in summer and for winter plowing if that makes a difference..
mongo66
10-10-2007 15:22:39
 Re: TRACTOR LUBRICATION on D17 in reply to MONGO66, 10-10-2007 08:07:06
thanks Mike for the expert advice, much appreciated on the info, I was a bit worried with my interpretation of the old manual, too many differing opinions from people not in the know....
DavidGrubb
10-10-2007 10:58:31
No trying to be a SA but the best thing to do is get an operators manual for your tractor. If you look in the upper left corner of the screen there is side bar called Marketplace that offers manuals. The genuine AC manuals are best I think.
MONGO66
10-10-2007 11:16:12
 Re: TRACTOR LUBRICATION on D17 in reply to DavidGrubb, 10-10-2007 10:58:31
I have a photocopied manual, just not specific enough on my question, it may be missing a few pages??? .. I just want to know what other people are using for upkeep ,thats all, never hurts to ask questions...
Skyhighballoon(MO)
10-10-2007 13:46:00
 Re: TRACTOR LUBRICATION on D17 in reply to MONGO66, 10-10-2007 11:16:12
First, lubes have changed from the 60's so reading original manuals still leaves some items open to interpretation.
You didn't say what Series D17 you have so the answer differs a little if you have a Series I or II vs a Series III or IV on where you add some fluids. I have a Series IV.
For engine oil, I run 10W-30, you could also run 15W-40 in the summer months if you need to change it that often. I wouldn't recommend 10W-40.
For hydraulics on a Series I or II it's added on the right side of the torque tube. On a Series III & IV the hydraulic and power director compartments are combined. Run universal trans/hydraulic fluid in both those. Look for the AGCO/Allis 821XL spec. You fill the power director compartment using the dipstick with a hex head to the left of the gear shift.
The transmission/differential is filled using the larger breather dipstick to the right of the gear shift. If you run your tractor hard like field tillage use 80W/90 EP GL-5 gear lube. If not, you can also use the same universial trans/hydraulic fluid. If this hasn't been changed in a while, drain, possibly flush with some diesel fuel & refill as condensation forms adding water to the case. Don't be surprised if you drain it and it looks like a brown milky sludge. I still run gear lube in mine.
The final drives are filled with plugs in the bottom inside of the pans. Also use 80/90 gear lube there. Fill till it runs out the hole.
If you have power steering, that is filled by removing the tall breather plug in front of the radiator/behind the grill. You can use either ATF fluid or universal trans/hydraulic fluid. This compartment also gets water in it easy and should be drained if not changed recently. Drain plug is underneath on the right side. I run ATF now but am switching to trans/hydraulic fluid here on the next change.
HTH. Mike
