wd traction booster
carl ac man
10-08-2007 17:58:51
how does it work and how do you go about ingaging it?
thank you carl
JMS/.MN
10-09-2007 10:36:59
 Re: wd traction booster in reply to carl ac man, 10-08-2007 17:58:51
The heavy spring above the drawbar senses wheel slippage and slightly raises the mounted implement, thus putting down pressure on the drive wheels. Linkage goes from the spring to the hydraulic valve. When the valve is set for Lift-Lower, per the instructions in the manual or the battery box, you engage the system by setting the lever above the Lower position. How high you set it determines how much weight transfer you get.
