ID allis chalmers
ol'reb
10-07-2007 20:32:15
I'm trying to help my father in law id an old Allis Chalmers tractor. The only thing I could find that looked like a model number was c 25 d stamped on the right side of the trans? housing. It has a tricycle front end and some kind of belly attachment system that looks aftermarket or homemade. The pictures look similar to the C bit I can't be sure. Thanks for the info.
old
10-07-2007 21:24:57
 Re: ID allis chalmers in reply to ol'reb, 10-07-2007 20:32:15
If its a C the number you need is just forward of the shifter and will start out with C. If you post a picture that helps a lot more because what you have said can fit a good number of tractors
ol'reb
10-08-2007 18:55:00
 Re: ID allis chalmers in reply to old, 10-07-2007 21:24:57
It will be a week or so before I will be back that way. I"ll try and get one. How about a metal bucket seat pan with a shift lever of some sort coming out of the top of the right hand axle housing? Big spring under the seat and under the bottom of the rearend?
ol'reb
10-09-2007 08:12:23
 Re: ID allis chalmers in reply to ol'reb, 10-08-2007 18:55:00
That sounds like that would be it. It is a four speed. I just googled CA and it looks to be
it. thanks.
ol"reb
Leroy
10-09-2007 04:13:46
I am not an allis man but that lever makes it sound like the live PTO on a CA. The CA has 4 speeds forward while the C has 3 and the CA has power shift rear wheels while the C does not. For a narrow front tractor the C & CA were the only models made without a channel iron frame untill the D series that included the D10, D12, D14, D15 & D17 that are a newer style.
