How to Mount AC WF Governor Housing
John
10-27-1999 18:07:02
I have removed the governor housing from a 1938 AC WF to straighten the shaft. I see no index marks on the governor gear, so my question is, how do I correctly mesh the governor gear to the engine gear????
Grandad
10-27-1999 19:34:37
 Re: How to Mount AC WF Governor Housing in reply to John, 10-27-1999 18:07:02
I think the WF is the same as the WC. If so the way I do it is bring #1 to tdc on the compression stroke. Then turn the mag drive shaft to horizontal and slide into place. make sure the slot for the mag drive stays horizontal. When you install the mag the #1 tower should be at 2 o'clock so point the rotor at 2 o'clock and slide it in place. That should get it running. From there you should be able to use the timing marks on the flywheel to fine tune it.
