Allis Chalmers D grader steering box
John C.
10-03-2007 09:07:53
I have a steering box from a Allis D Grader, it says "gemmer" on the side. The gears inside are damaged and I need to replace them. Does anyone know if this box was used on any other Allis Models or have a source for these parts?
Thank You
John
Don, BC
10-05-2007 10:20:13
 Re: Allis Chalmers D grader steering box in reply to John C., 10-03-2007 09:07:53
I have a D grader so I am always on the lookout for doner machines and salvage yards in the event that I will need parts. A contractor near me has adapted the steering box from a Ford Bronco to his machine to give power steering. He may have a good steering box for sale. I will contact him because I am adapting power assist to my machine and I would like to find the steering arm along with the drag link from a machine with non tilt front axle to help make the conversion on my machine with tilting front axle. You could try Thill Tractor at: www.thilltractor.com
I would also like to hear from anyone who knows about any D grader doner machines.
Thanks,
Don
JohnC
10-09-2007 08:23:57
 Re: Allis Chalmers D grader steering box in reply to Don, BC, 10-05-2007 10:20:13
Don, Appreciate any & all connections and information. Let me know if your contractor friend has a good original box to sell. Regards, John
Kentb of SWMO
10-04-2007 06:47:49
Local guy has on of these blades. His steering box went south. He adapted a GM steering box and got power steering as a bonus. He belt drove the pump from the engine.
Kent
DavidKittle
10-03-2007 16:49:41
Hello;
Whe I couldn't find parts of this order I had luck with using pencil rod to build up the bad part, grinding down to where it needs to be.
I hope this helps.
old
10-03-2007 09:32:05
Try this phone number. This place had parts for my Gallion 303. #740-439-5512
