hard starting
randy47
10-02-2007 10:30:53
my allis B starts and run great cold. Half a flip on the starter and its running fine, idles great but after you run it for an hour or so you have to play with the throttle alot to get it to start back up once it has been shut off. it will only restart if the throttle lever is in the slow position Ive cleaned the carb and checked the plugs ...it has a mag.. any suggestions Randy
me too
10-03-2007 03:21:32
 Re: hard starting in reply to randy47, 10-02-2007 10:30:53
Do you have to choke it and low throttle? Found mine wanted just a second of choke (engine cranking over, just a quick pul/push) to start even when warm. Suspect minor vaccum leak bit not enough to bother it running.
CWL
10-02-2007 13:43:20
Could it be the condensor starting to get weak?? I've seen them start to go bad in small engines where the motor would die after it got warmed up and would not restart until cooled off. Replacing the condensor fixed that problem. Just a guess.
randy47
10-02-2007 14:22:13
 Re: hard starting in reply to CWL, 10-02-2007 13:43:20
its not that it wont start hot just HARD to start hot but thanks for the condenser suggestion
Dick L
10-02-2007 11:53:14
Two things that I have found but they dont line up exactly with the starting different between cold and hot.
If the venturi is larger that the engine should have it will not start well with the throttle opended up. Normally hot or cold.
If you have some buildup behind the power jet just below the feed tube they tend to start hard. You stated that you had cleaned the carb. In cleaning it did you remove the power jet and feed tube? With both removed did you put a small drill bit in the holes by hand and work out any build up out of the bottom?
Normally not a problem connected to hot or cold.
