Allis WC and WD engine blocks
matt06br
10-01-2007 18:19:55
My allis wc block is craked between all the pistons and has a freeze crack on the side. I was offered a WD block for a good price and I was wondering if they were compatible, I was told that they were. Also will my WC head work on the WD block.
Jack a
10-02-2007 12:51:56
 Re: Allis WC and WD engine blocks in reply to matt06br, 10-01-2007 18:19:55
Very early WC heads didn't use the 3/8" head bolts/studs.
Bill(Wis)
10-02-2007 21:17:26
 Re: Allis WC and WD engine blocks in reply to Jack a, 10-02-2007 12:51:56
Are you referring to the engines from Waukesha?
Jack a
10-03-2007 07:00:13
 Re: Allis WC and WD engine blocks in reply to Bill(Wis), 10-02-2007 21:17:26
No. The early AC engine for the WC. Brother has a 34 with AC engine and no place for the 3/8" studs.
JMS/MN
10-01-2007 23:13:11
Both used the same 201 cu inch block. WD would have a few more horses with the higher governed speed, courtesy of a different governor spring. Bolt it in!
A/C Boy
10-01-2007 20:31:56
I got a wc parts tractor, i think the block is good head and all.
old
10-01-2007 19:02:42
The WD and WC used the same engine. So yes that block is the same 100% other then a few little stuff like the tranny and maybe the gov.
Bill(Wis)
10-01-2007 18:38:10
Yes and yes.
Bill(Wis)
10-01-2007 18:38:03
Yes and yes.
