WD 3rd point
Texas Denny
09-23-2007 06:15:13
Does anyone know where you can buy the U that fits over the lift arm shaft that can be used for the third point? A guy I know wants to use a three point back blade with his WD. His WD has just the lower arms of the three point for use with a shredder. Thanks,
Mike in Ohio
09-23-2007 19:44:04
 Re: WD 3rd point in reply to Texas Denny, 09-23-2007 06:15:13
Denny search the archives on tha allis page for BobHnwOh go to #14 it will say something about a 54 wd45 if you look at all the related posts you will see where he answered my questions about his setup too. If you have a welder and some scrap around it looks like the way to go to me. Good luck, Mike
Texas Denny
09-23-2007 20:01:56
 Re: WD 3rd point in reply to Mike in Ohio, 09-23-2007 19:44:04
Mike, I found the picture that you describe. I really like that idea and will use it on my own WD-45. The acquaintance will most likely go with the U bracket because it is easier. Thanks for the input!
Mike in Ohio
09-23-2007 21:20:05
 Re: WD 3rd point in reply to Texas Denny, 09-23-2007 20:01:56
Glad I could help, usually I'm the one needing help. It's nice to be able to give a little back to the group. Mike
Mike in Ohio
09-23-2007 19:29:12
Denny check the archives for a wd45 deisel post about a month ago one of the answers had a picture of a much better setup. I will try to find it and let you know where it is. Dad has the U shape piece you mention I think he got it at tonys tractors on line but you do need 2 muffler clamps to hold it in place. Kind of a pain. good luck Mike
Bill(Wis)
09-23-2007 16:21:14
I guess you have the info you need. He might need to put a muffler clamp on each side of the U clevis to keep it centered on the rockshaft. Sideways drift of the clevis is the only problem I've had and that was mainly while mowing ditchbanks.
Texas Denny
09-23-2007 15:02:38
 Re: WD 3rd point in reply to Coloken, 09-23-2007 06:47:43
Thanks,
old
09-23-2007 17:05:03
 Re: WD 3rd point in reply to Texas Denny, 09-23-2007 15:02:38
Texas, my self I just make them. I have also found that ones like that don't work as well as one that is mounted solid the the rear end area. There not hard to make if you have the metal laying around and a welder
Texas Denny
09-23-2007 20:30:52
 Re: WD 3rd point in reply to old, 09-23-2007 17:05:03
I'm with you. I didn't want to make the part for him even though it is easy. Just wanted to help him with some options that he could handle without help. Thanks,
