not getting oil to the valves
glenn allen
09-22-2007 17:34:53
the motor has good oil pressure but no oil is getting to the valves
DARDAN
09-23-2007 20:08:05
 Re: not getting oil to the valves in reply to glenn allen, 09-22-2007 17:34:53
Try loosening the tube nut on the oil line where it goes into the head. If it runs oil with the tractor running, then the stoppage is in the head. If not, try loosenig the lower end of the tube.
Wild Bill
09-23-2007 18:09:42
Glenn, there is one stud that the rocker arm attaches to that has a groove (rearmost IIRC, at least on the B,C, and CA). Make sure that the groove is pointed to the oil line entering the head, it lets the oil flow up and onto the rocker assembly.
El Toro
09-23-2007 03:51:17
You may have sludge blocking the oil flow to the rocker arms. Hal
Gene
09-22-2007 18:40:49
glenn allen said: (quoted from post at 17:34:53 09/22/07) the motor has good oil pressure but no oil is getting to the valves
It would help to know which model tractor and which engine. Was the head removed and worked on recently?
