water in final drives
bundy
09-20-2007 20:41:09
where does the water come from that gets into my finals? i think the brakes. no water in tranny. just bought a c with a woods mower on it for $700 runs good no wierd noises.
DARDAN
09-23-2007 19:58:35
 Re: water in final drives in reply to bundy, 09-20-2007 20:41:09
Just thought of another possibility. If the 1 inch holes in the bottom of the axel tubes, below the brake drum and bands, is clogged with dirt and stuff, rain/wash water may accumulate enough to get past the seals between the brakes and final drives.
Tarping is a pain, but it will avoid other various water caused problems. I could list at least a dozen other things where a bare B, C, CA tractor takes a beating in the weather.
Goose
09-22-2007 21:15:16
Most likely condensation. It's the pits when you let a tractor set for a few weeks in sub-freezing weather, then go to use it and it won't move because condensation has settled out of the gear oil and frozen in the bottom of the case.
Happened to me twice, once on an H Farmall and once on a VAC Case.
1755
09-22-2007 19:30:31
I dont know for sher in your case but water also gets in there when you try to get to caryed away with the power washer around the vents and seals dont know for sher on final drives but I have done it to the trans and rear on a few trying to clean them up for a show
dardan
09-20-2007 23:42:46
If the tractor spent it's life in the east, with the high humidity, it may well be condensed water accumulated over many years. Every old tractor that I have dealt with had some water in all the gear cases, from a few drops to quarts. Also, if someone forded deep water, or stuck in a creek somewhere in it's history, the water may have seeped past the axel seals. I always drain and flush all gearcases on old tractors as a catch-up mantainance, because most old farmers were pretty cheap when it came to lubes.
bundy
09-21-2007 20:47:17
 Re: water in final drives in reply to dardan, 09-20-2007 23:42:46
thanks for the reply. the person knew water was getting into drives but didnt know where from. i drained them today and there was as much water as gear oil. so i removed the covers and cleaned it all out i guess ill just have to tarp until i figure it out. i also drained the fuel tank looks like somebody did a bad relining job pulled a 8" square piece of lining that was floating around. quess thats next on my list.
