WD45 hand clutch slips
Hal
10-25-1999 21:19:04
We have a WD45 that has a hand clutch that slips when pulling heavy loads. We took the top cover off the hand clutch and removed 3 or 4 of the thin shims from each pair of bolts a couple of years ago. The hand clutch seemed to "snap" in tighter but it has begun to slip again. Thanks for any advice.
bentorbroke
10-27-1999 06:45:48
 Re: WD45 hand clutch slips in reply to Hal, 10-25-1999 21:19:04
You may have worn out clutch disks. Check to see if you still have grooves in the clutch facings, if not you probably have worn out clutch disks. If you still have grooves in the clutch disk facings, then remove shims to get a total clearance of .030 when the clutch is not engaged. It is common to have to take out all shims on worn clutches. Also check to see if one of the clutch disks has sheared the rivets holding it to it's hub. When both of the disks shear the rivets holding them to their hubs the tractor will not pull itself at all. (Simply no transfer of power.) Be sure that you have the correct lubricant in the transmission and torque tube assy (where the hand clutch assy. is located); there should be no teflon additives, molly additives or any lube other than that recommended. If you have to replace the clutch disks or repair the disks (replace rivets) it is a MAJOR take it ALL apart and put it back together job. Good luck, hope that you don't have to replace or repair the clutch disks, bentorbroke
Hal
10-27-1999 06:51:47
 Re: Re: WD45 hand clutch slips in reply to bentorbroke, 10-27-1999 06:45:48
Thanks for the help bentorbroke.
