final drive
huntercon
09-19-2007 08:15:06
1949 allis B is sae 20wt the right wt and will i need to make new gaskets after pulling the pans thanks again.
huntercon
09-19-2007 12:49:20
 Re: final drive in reply to huntercon, 09-19-2007 08:15:06
thank you guys for you input i just finished a 5 year restoration and now its just fluids.
Texas Denny
09-19-2007 10:43:28
Old is right on. I think you have the 20W mixed up with the transmission. The lower drives take gear oil.
old
09-19-2007 10:06:51
I use 80W-140 in the bull gear pans and HYTRAN in the tranny/hyds/rear end on my Cs which are almost the same as your B other then the C is wider in the tail end and has a trike front end. As far as the gaskets you can buy then from AGCO or use silicone which is what I did the last time I change the oil in my C
