D 17 hitch pin size
tim[in]
09-18-2007 15:08:59
I am going to try to move my 14x70 house trailor a couple hundred feet on my farm. Its sunk in a few inches and I think to move it and get it going i am going to have to get more traction on my series 1 D 17. I am planning to use a ball on my drawbar that is over 2 inch diameter and rated for about 10000 #s. They have two available and one is a 3/4 " shaft and the other a one inch shaft. I never thought to measure mine when i was at my farm 90 miles away. Does anyone know if a 1" pin will fit in the drawbar? Thanks in advance!
M Nut
09-22-2007 04:47:38
 Re: D 17 hitch pin size in reply to tim[in], 09-18-2007 15:08:59
I had a 12x60 I gave away a few years ago. Guy came to pull it away with his D-17, and the drawbar bent and the frontend just lifted into the air. Ended up using a large tandem truck, and then a frontend loader with a ball in the bucket pulling backwards to put it into place at his farm.
william myers
09-19-2007 13:23:57
its a 2 an 5-16th ball with a 1 inch stud, like the other guy to much weight for a d17
JMS/MN
09-18-2007 15:25:56
I would not consider using the D17. Way too much tongue weight on that trailer. Likely to bend the drawbar or pull out the bolts that hold it to the differential casting. I've moved a couple that size with 120 hp JD tractors with much thicker drawbars and better mountings. Neighbor tried moving his with a 706 IH (70+ hp) and bent the drawbar.
