Taken sleeves out?
TroyR
09-18-2007 08:07:36
#25550-B.Any fancy tricks on getting the sleeves out?I haven't tried yet,but I thaught I'd ask to make it easier.Also When I put them back in,just put the o-rings around the sleeve and put it in an oily cylinder.Do I have to order them,or can I get them from NAPA or somewhere else
A/C Boy
09-19-2007 20:33:35
 Re: Taken sleeves out? in reply to TroyR, 09-18-2007 08:07:36
Best way I found was to turn the block upside down and use a block of wood and my little 20 ton press. Just pushes them right out. When Installing new sleeves install packing rings in grooves in the block without twists. And be careful not to stretch rings or they will not fit in the block grooves. Lubricate packing rings and lower portion of liner with Castor Oil. You can get it at the drug store. Castol oil does not cause the rubber rings to swell. Also, be sure to clean all the build up out of the grooves.
Dick L
09-18-2007 14:52:18
Fastest Sleeve Removal System.
third party image
glennster
09-18-2007 09:50:26
here are 2 types of sleeve pullers, they arent to hard to make. when installing wet sleeves, dip the o ring in dish soap and set it in the groove. then slide the sleeve in it. on some engines, the sleeve will walk out when the cylinder head is off, you can just turn the motor over by hand and the piston will bring them up if they arent stuck
third party image
Texas Denny
09-18-2007 09:40:34
They have pullers available for that purpose. I made one using a threaded rod, a disk matching the diameter of the bottom of the sleeve a bar 2 inches longer than the outside diameter of the top of the sleeve and a couple of small blocks that fit under the bar and sit on the top of the block. I just tighten the nuts on the rod and the sleeve comes right out. Before reinstalling the sleeves, make sure they slip into position easily without the o-rings. If they don't, the surfaces need more cleaning.
Most parts dealers can get these rings. Maybe NAPA would have them. Never tried them for these o-rings but they have had stuff I didn't think they would have. Rusty Acre at 507-433-0073 can get them.
DavidKittle
10-17-2007 10:51:09
 Re: Taken sleeves out? in reply to Texas Denny, 09-18-2007 09:40:34
Texas Denny;
I had a couples of questions if you don't mind.
Can a guy hone out the cylinders and install new rings on a D-17 WITHOUT taking the engine out, doing this job inframe? As of yet I didn't do anything with the tractor yet , just looking for a cheaper alternative to buying a complete overhaul kit. gotta live on a budget you know!
Also if the answer is yes, can you do the same thing to a B?
Thanks
