Putting Shifter Boot on a 'B'--Easy Way!!!
Pappy
09-17-2007 19:57:13
I might be the only person on this board who has just learned this trick, but I found it very difficult to place a new shifter boot on out '39 'B'. Finally, after much head-scatching, I turned the boot inside out and placed it over the shift lever upside down. I pushed it down to the bottom, and just rolled the outer edges down just as you would roll down the cuff on your jeans. It was easy.
Allis nut
09-17-2007 20:21:46
 Re: Putting Shifter Boot on a 'B'--Easy Way!!! in reply to Pappy, 09-17-2007 19:57:13
Another way that has worked for me is to put the boot in hot water and let it soak for a minute or two it loosens the rubber and makes it esaier to work with.
