Adjusting hand clutch shims
Dan Lauters
09-15-2007 05:55:01
I am adjusting my wd's hand clutch. Must I take all three shims out? May I leave two shims in and only remove one shim? The proper adjustment seems to be wih one shim removed and then tightened to the width of half of the shim. Will the clutch wear unevenly at this adjustment? Without adding a smaller shim will the bolts stay at this adjustment? I do not want to put it together this way and have problems in the middle of the winter. Please reply. Thanks.
JMS/MN
09-16-2007 15:06:31
 Re: Adjusting hand clutch shims in reply to Dan Lauters, 09-15-2007 05:55:01
You add or subtract the same number of shims at each location- no matter how many or few. Each location should have the same number in.
