Will a D17 make a good loader chore tractor???????
Rickyp
09-13-2007 12:40:43
The loader hyds is run off of the PTO and it stops everytime you push the clutch in. Just wondering what you all think. Ricky
Richard E.
09-14-2007 10:02:42
 Re: Will a D17 make a good loader chore tractor??????? in reply to Rickyp, 09-13-2007 12:40:43
A front mounted pump would make it an ideal tractor, used to drive one. Then we up-graded to a series 4 and it had a mid-mounted pump that worked better ! Dual wheel weights and loaded 18.4x28 even helped more. My 2 cents.
Richard E.
09-14-2007 10:01:16
Jack a
09-14-2007 04:17:05
Use the hand clutch. Works for me. I only push the foot cluch when I need to change gears. I usually am not trying to lift when going from forward to reverse. Look for an I60 or I600. That's a D17 or D15? with shuttle transmission and heavy front axle..
Tom from Ontario
09-13-2007 17:03:03
We have a D17 and that's what we use it for and I would hate to think of being without it. Has been 26 years, BUT we have the 417 loader with a front mount pump. It's been a dandy.
Good Luck.
william myers
09-13-2007 14:37:19
Have a loader on my 17, if ur not doing alot of frontend work its fine, the way it is.. The power dir. helps alot if its working properly...
RN
09-13-2007 12:47:09
I used IHC H with same type setup - it's usable with a bit of forethought, no big deal. If you want live hydaulic on that particular tractor get a engine driven pump. Some threads in archives about mounting Char-Lynn units, some on truck powersteering pump mounting. RN
John (MO)
09-13-2007 12:44:29
If your power director is working good it should be ok. You would be better off finding a front mounted pump when you can though.
