1943 B brakes
dale lundy
09-13-2007 05:37:57
I am at the point of trying to remove the brake drum band ,The slack adjuster is seised and I want to remove it in order to either repair it or replace it. can anyone help me ... I've already removed the fender,fender bracket and brake cover, brake band pins and spring.
Dick L
09-13-2007 11:52:56
 Re: 1943 B brakes in reply to dale lundy, 09-13-2007 05:37:57
Wire a chain to one end and get a long pry bar. If you are lucky you might be able to save the old band to reline. You pull/pry over and down. Helps to turn the tire at the same time.(Some times)I turn a burnsomatic torch with a yellow tank on the adjuster pin to be able turn it. Not on the screw, just the threaded toggle pin.
third party image
