WD Govenor...
Travis A
09-10-2007 10:32:42
The govenor on my dads WD doesn"t work, and hasn"t since we bought it I weas wondering how it works?? and what might be wrong with it...thanx
MLPANKEY
09-12-2007 19:56:22
 Re: WD Govenor... in reply to Travis A, 09-10-2007 10:32:42
FIND THE DISTRIBUTOR THE GOV IS ATACHED IN FRONT OF THE DIST. THE FOUR BOLT COVER IS IN FRONT OF THE GOV .STANDING AT SIDE OF TRACTOR LOOKING BACK TOWARD REAR END THE COVER IS VISIBLE IN SPACE BETWEEN RADIATOR AND ENGINE THE THROTTLE ROD GOING TO THE THROTTLE LEVER ATTACHES JUST ABOVE AND TO THE SIDE OF THE COVER.
Travis A
09-13-2007 10:19:32
 Re: WD Govenor... in reply to MLPANKEY, 09-12-2007 19:56:22
Took off cover...spring looks good??
mlpankey
09-13-2007 13:04:55
 Re: WD Govenor... in reply to Travis A, 09-13-2007 10:19:32
pull the gov lookat the weights see if they move free on the pins they should be floppy
mlpankey
09-10-2007 21:48:32
take it out look to see if the weights move freely on the pins that hold them in place also look for cracks in the weights . replace the gov. spring in the front cover of the gov . good chance its stretched. if wieghts move free new spring then put it back together . with the engine not running pull the throttle wide open hold it there with visegrips check to see if carb lingage has carb wide open if you pull lingage from gov shaft it should have a slight pressure on gov. i thing its 3/16 measurement to linning up exactly with the hole thats the carb rod to gov. arm.
JMS/.MN
09-10-2007 21:41:49
Broken spring? very common.
Travis A
09-11-2007 09:13:24
 Re: WD Govenor... in reply to JMS/.MN, 09-10-2007 21:41:49
where would the spring be located?
mlpankey
09-11-2007 23:06:33
 Re: WD Govenor... in reply to Travis A, 09-11-2007 09:13:24
directly in front of the govenor theres a four bolt cover its behind it.
Travis A
09-12-2007 06:56:38
 Re: WD Govenor... in reply to mlpankey, 09-11-2007 23:06:33
I"m gonna sound like a idiot, but where"s that..on the throtle cable side? or where it crosses over by the radiator to the carb?
