WHAT ENGINE OIL IS BEST
Phil H
09-09-2007 16:53:05
I recently bought an AC 7060 and looking through the operators manual it says DO NOT USE MULTI-VISCOSITY LUBRICATING OILS IN ALLIS CHALMERS DIESEL ENGINES. I also have a CASE 450 crawler and a 671 detroit in an IH. truck, I use straight 30# in the CASE and the truck, but everyone seems to be going to 15/40# oil and most bulk suppliers don"t cary anything else. Is this just the new thinking or is the new oils actually a lot better now than when these engines were designed? The temps. are never down lower than 32*F. What do you all think???
mike s
09-10-2007 12:00:49
 Re: WHAT ENGINE OIL IS BEST in reply to Phil H, 09-09-2007 16:53:05
In my 8v92 I use delo 100 40w it made for those 2 cycle engines. In the 190xt and 8050 I use delo 400 15w-40. We have been using delo products since 1962 and they have worked out real well.
LenND
09-10-2007 13:11:02
 Re: WHAT ENGINE OIL IS BEST in reply to mike s, 09-10-2007 12:00:49
It seems like about once a week we see the question of what oil is best. I think the answer to that is if you have been using brand X for twenty years and have no trouble why would you want to change just because someone else says brand Y is better. Ifyou have newer equipment most use 15/40 by the books. If you have old timers like me I use 10/30 in everything I have except my old 900B and that is straight 30--don't use it in the winter.
Phil H
09-10-2007 06:04:30
Thanks ALL for the comments, I know the 15/40 would circulate a lot faster when started, I was hoping for one oil for all machines, and my guess is these new oils are a lot better today. My 7060 is a RED FRAME not sure what that means, but I will give this OIL some more thought. Phil H
Kentb of SWMO
09-10-2007 05:34:39
Two stroke Detroits spec 40W oil no matter the temp. 30 W as a second choice. NO Multi-viscocity's. The book prefers the use of 40W oil and heat the engine for cold weather starting.
Kent
Oldcraneguy
09-10-2007 03:29:44
I dont know why A-C doesnt want you to use multi-viscosity oil, but if my supplier wont get what I need I'd get a new supplier! That being said, I should note that Im in an area with dozens of petroleum distributors, you may not be so lucky.
BobHnwOh
09-10-2007 03:24:58
Phil,oils have changed a lot since your manual was printed,I plan to change to Rotelle Synthetic 5-40 in my 7060 next spring,I put it in my 580B TLB several years ago,works great,Bob.
BENJAMIN KIMM
09-09-2007 18:39:29
We always ran 15w40 with no problems. Is your tractor a red or black frame
Wisconsin Cowman
09-09-2007 18:23:18
It would not hurt the engine to use 15W40 in summer and 10w30 in winter. Use it in all my engines from lawn mowers to my Oliver 1955 never have problems.
