T811 Lawn Tractor
komputatek
09-08-2007 06:44:49
I recently bought one in very good condition except it has no engine. Can anyone tell me what the original engine was?
Thanks!
cadet trooper
09-13-2007 16:19:34
 Re: T811 Lawn Tractor in reply to komputatek, 09-08-2007 06:44:49
Should be a vertical crank 11hp Briggs and I think it should be a GT811 stands for garden tractor versus LT lawn tractor the GT has somewhat of a frame versus the 600 series. The one key is the crankshaft length for pulley mounting for the transaxle drive and the mower deck. I think finding an engine will be easier than making sure you have the pullies for the tractor other wise you may have to get that through Agco. Also throttle design. My two cents. CT
komputatek
09-14-2007 07:28:33
 Re: T811 Lawn Tractor in reply to cadet trooper, 09-13-2007 16:19:34
Thanks to both of you. I had not heard of the simpletractors website. I enjoyed reading it.
I"m thinking about putting a B&S 12HP on it that I have. I believe the shaft is the same and I do have the pulley from the engine so it should go well.
I am planning on it being a winter restoration
Thanks again!
cadet trooper
09-14-2007 15:22:07
 Re: T811 Lawn Tractor in reply to komputatek, 09-14-2007 07:28:33
Good luck to ya, I just did the reverse on a 1225 Cub Cadet put a 11hp on it which should have a 12hp I/C with an electric clutch for the mower deck and had to scrap the mower deck. Works for me because I just need it for spraying and other menial tasks because my other tractor is too big and costly. I had a little problem with the throttle location but got that worked out works fine. CT
Bob
09-08-2007 11:10:18
Check over at simpletractors.com.
