AC C shifting issue
Oliver1800A
09-07-2007 09:47:46
Hi guys,
I have a question. I have a C that gives me trouble when shifting from a forward gear to neutral. When I let the clutch out after shifting into neutral, it is still in gear. In order to get it out of gear, if I take the shifter to reverse and then back to neutral. Is the clutch not disengaging? I appreciate the help and advise.
ohio
09-07-2007 15:27:39
 Re: AC C shifting issue in reply to Oliver1800A, 09-07-2007 09:47:46
little slots & gates in the shift mechanism are prolley slopped out. square 'em up with a welder & file 'em clean.
ohio
09-07-2007 15:28:44
 Re: AC C shifting issue in reply to ohio, 09-07-2007 15:27:39
or somthing is bent. straighten it.
Dick L
09-07-2007 11:30:16
You might be able to repair the shifter fork mechanism that is part of the side plate on the transmission. I see them sell on Ebay fairly cheap from time to time. You should be able to see what is needed after removing the side plate.
