wd 45
greg b
09-05-2007 09:47:09
hi my wd 45 starts fine then it just quits then it will start back up again does this over and over , changed magneto to distributor still does same thing, any ideas ? thanks in advance.
old
09-05-2007 10:42:56
 Re: wd 45 in reply to greg b, 09-05-2007 09:47:09
I would pull the drain plug out of the bottom of the carb and make sure you have a good steady flow of gas for 5 minutes or more. Catch the gas so you can look at it and make sure its not full of rust etc. If you don't have a good staedy flow there pul the fuel line off the carb and check there the same way. If you have it at the line and not the carb then you have a clogged up carb. If you don't have it either place then you have a glogged fuel line/sediment bolw or a clog in the tank
