WD 45 won't stay running
ranger80
09-04-2007 20:23:55
I have a wd-45 I have a problem it will start and as sone as I put it in gear it starts running bad and won't hardly run I feel it is in the fuel as sometimes it levels out when choke is pulled out. I have takeen and cleaned the feul line the bowl and the carb but no luck am I missing something? Thanks
carl ac man
09-08-2007 19:03:09
 Re: WD 45 won't stay running in reply to ranger80, 09-04-2007 20:23:55
on the bottom of ur carb twards the front of the tractor there should be a lil metal rod bent 90 degrees that controls the ammount of fuel to the carb try loosinin it and see if that fixes your problem
El Toro
09-05-2007 07:39:16
Shine a flashlite down in the gas tank and see if any rust or dirt are blocking the outlet. Your carburetor may have a screen at the inlet to the carburetor and is full of dirt or rust. When you need to use the choke is a good sign the engine is starving for gas. Hal
jeffalex2
09-05-2007 03:20:05
That could be a bunch of stuff. Make sure you got strong fuel flow out of the tank. The float could also be flooding the carb. I had the same problem and also thought it was fuel related, to the point that I rebuilt the head...turned out it was a weak mag issue...make sure you have a nice strong spark on all four plugs. And if you have batt ign, make sure points, and condenser are OK.
Eldon (WA)
09-04-2007 22:04:11
Check the main jet seat and setting on the carb and make sure it is ok and set right.
