C question
jk
09-04-2007 15:37:29
i have a 42 C. i know the C or the CA's never had a tachometer, but is there one for mabee the D series i can put on my C? i would like to be able to see the engie RPMS at a glance. just wondering.
jk
Texas Denny
09-04-2007 19:15:43
 Re: C question in reply to jk, 09-04-2007 15:37:29
If you have converted your tractor to 12 volt ignition, most any electric tach will work that has setting for the number of cylinders (most do). If you are on 6 volt, you will need a D-14 distributor, cable and tach. Its probably simpler to go to 12 volt, negative ground.
colby IN
09-04-2007 17:01:42
we have one on our WD that we had layn around its just ur normal racing tach made by sunpro heres a pic hopefully
third party image
Dick L
09-04-2007 16:20:20
It will work. We used the governor shaft and gear from a D-15 in a CA housing without the drive casting. The only difference was the end of the shaft that drives the cable. You will just have to get the complete assembly.
jk
09-08-2007 18:44:37
 Re: C question in reply to Dick L, 09-04-2007 16:20:20
DickL
can you post a pic of the tach on your tractor? thanks
jk
