Where is the fuse box on a 7020 Allis Chalmers
Rick ONeal
09-02-2007 11:44:17
I have looked all over for the fuse Box. Anyone know were it is? Please help! Allis Chalmers 7020
Joe(TX)
09-04-2007 05:13:07
 Re: Where is the fuse box on a 7020 Allis Chalmers in reply to Rick ONeal, 09-02-2007 11:44:17
There are circuit breakers on the fire wall on the engine side on the right. There are also some under the cab roof for the cab items.
By the way FYI, a 3/8 bolt has a 9/16 head.
cadet trooper
09-04-2007 14:50:57
 Re: Where is the fuse box on a 7020 Allis Chalmers in reply to Joe(TX), 09-04-2007 05:13:07
I think we're getting off track here, Rick needs to give us more info as to what's not working or he's found the problem already thus the point is moot not basic mechanics 101 dealing with hexhead capscrews and combination wrench sizes SAE. Have a nice day :-)
Bob
09-02-2007 19:32:27
I recall there's a couple of breakers on the FRONT of the firewall, behind the RH side of the engine, not sure about any other "circuit protection".
cadet trooper
09-03-2007 13:04:44
 Re: Where is the fuse box on a 7020 Allis Chalmers in reply to Bob, 09-02-2007 19:32:27
Wow Bob,you're really taxing the old memory banks here that's been close to twenty years or more ago since I've fooled with those old girls you might try the black panel just under the instruments and just above the clutch and brake pedals be careful opening that up you might have a mouse staring at you which could be the source of some electrical issues if I remember right that is also where the flasher relay is. I can't remember if there are two or four screws holding it in place. Don't shoot at me if I'm wrong like I said it's been a long time ago some days I can't remember what I had for breakfast and I have the same thing everyday. If you have your manual it should be in there. Also if you need a manual I just ran across a booth yesterday that had a barn full of them and really pretty reasonably priced. Good Luck CT
BobHnwOh
09-03-2007 15:24:03
 Re: Where is the fuse box on a 7020 Allis Chalmers in reply to cadet trooper, 09-03-2007 13:04:44
My 7060 has 8- 3/8 bolts holdin that plate on!!Bob.
cadet trooper
09-03-2007 17:23:35
 Re: Where is the fuse box on a 7020 Allis Chalmers in reply to BobHnwOh, 09-03-2007 15:24:03
Like I said I can't remember but I'm relatively sure that's where it is but just couldn't remember how many bolts they did that to seal up the cab and cut down on vibration I still don't think there's any circuit breakers though might be some fuses. Funny you said 3/8's bolts because I was going to say a 9/16" wrench but I'm thinking man that's awful big for just a dirt panel but when you spend a lot of hours in those tractors you seem to remember things like that.
