Wheel wobble on 39 B
Hand Crank
09-01-2007 19:25:54
One of the rear wheels on my B is loose in the hub.Is this a bad bearing,spacer or????.Don`t have a wrench that will fit the oddball nut.Any ideas on this one?Alsothe shifting lever spins in all directions.(It shifts fine.)Is this a bad thing?. Thank`s for any help, Don.
steve(ill)
09-01-2007 19:35:45
 Re: Wheel wobble on 39 B in reply to Hand Crank, 09-01-2007 19:25:54
you need to tightne the rear nut with a big pipe wrench or cresent, etc. when it is tight, see if the hub still moves on the splines. (the 2 inch nut tightens the hub on a tapered spline). if it dont get tight, them remove the nut and see if it needs a washer under it, if it is bottoming out on the spline sticking thru the hub. if thats not it, it might be on the inside (back of the splines). you need to jack the wheel up and inch off teh ground and pull the hub off the splines and look at the splines. might be the lip on the back of the hub is bottoming out on the case and needs to be ground down with body grinder. if the splings are torn up, you can buildup with liquid steel typ material, or replace the hub!.---- the trans shift has a ball on the end- that is normal.
