24 inch wd wheels
chickie
09-01-2007 08:43:52
looking for a pair of 24 inch 8 bolt rear rims to fit a WD,i dont know if they even made such a rim,mabey some one would know of another tractor wheel that would fit. thanks
Tradititonal Farmer
09-03-2007 19:07:43
 Re: 24 inch wd wheels in reply to chickie, 09-01-2007 08:43:52
International made a variety of 24" rims that will bolt on a WD I have a couple of sets.Where are you located?
Stan Kinney
09-04-2007 18:57:49
 Re: 24 inch wd wheels in reply to Tradititonal Farmer, 09-03-2007 19:07:43
Could you tell me what model IH rear rim will bolt to a WD. I'm in Ohio. Looking to find replacement rear rims/wheels for the WD
Eldon (WA)
09-01-2007 20:23:35
I have a set of 24" fixed wheels sitting on an old WD45. They came off of an I-40 industrial tractor, but have to be reversed to clear the drop axles (makes for one wide tractor). Wheels off of an I-400 will also fit.
Aaron SEIA
09-01-2007 18:35:19
I've just gotta ask...why such a small rim? They came with 28" and I don't mean to be rude, but a 24" would look just goofy.
Aaron SEIA
Eldon (WA)
09-01-2007 20:25:44
 Re: 24 inch wd wheels in reply to Aaron SEIA, 09-01-2007 18:35:19
24" wheels with industrial tires are about the same height as the 28"
A-C hayman
09-01-2007 11:34:24
The older WC's had 24 inch rims
JMS/.MN
09-01-2007 12:58:39
 Re: 24 inch wd wheels in reply to A-C hayman, 09-01-2007 11:34:24
True- but a six hole pattern, would not match the WD hub.
JMS/MN
09-01-2007 10:05:00
Older combines used 26 inch wheels- I think a 55 JD has the same bolt pattern as the AC. Getting down to 24 inch might be a struggle.
