Help with model # of sickle bar mower
Bill Crofutt
08-31-2007 17:13:41
I have a A-C sickle bar mower and cannot find the knives for it. Tractor supply doesn't have any that match and the local dealer doesn't have any that fit either and without the model number isn't able to help me. I can't find a model number on it anywhere. Can anyone help? Four of the knives have sheared off and of course it cuts terrible now. Thanks!
Bill
patsublett
09-01-2007 13:15:22
 Re: Help with model # of sickle bar mower in reply to Bill Crofutt, 08-31-2007 17:13:41
If you have a BC mid mount, Knives for a John Deere model #7 or #9 will work. IF TSC don't have them they can order.
Jerry Coulter
09-01-2007 09:43:43
I have some AC mower reference material. I need some description. What tractor is it attached to? How does it attach - under belly, trailer, semi-mount trail with caster wheel, rear snap coupler, 3 point hitch? If under belly, is it driven by roller chain, 1 or 2 V belts? Is the sickle driven by a pitman stick? If you can find a casting with a number on it - likely 6 digits beginning with 3, that could help. Do you see any indication that a craftsman with a welder has retrofit a different bar assembly?
Bill Crofutt
09-02-2007 20:00:23
 Re: Help with model # of sickle bar mower in reply to Jerry Coulter, 09-01-2007 09:43:43
third party image
Here is a picture of the mower. Thanks!
Bill
Jerry Coulter
09-04-2007 09:47:54
 Re: Help with model # of sickle bar mower in reply to Bill Crofutt, 09-02-2007 20:00:23
The AC part number is 802535 for the smooth section and 802541 for the underserarated section. Add a 70 prefix to translate to the AGCO part number.
Jerry Coulter
09-03-2007 17:30:02
I can't get any picture out of this. Jerry
Bill Crofutt
09-03-2007 17:37:19
 Re: Help with model # of sickle bar mower in reply to Jerry Coulter, 09-03-2007 17:30:02
third party image
Right click on it and "get picture". That works for me. If not, here is a link you can try
Link
Tradititonal Farmer
09-03-2007 19:10:40
 Re: Help with model # of sickle bar mower in reply to Bill Crofutt, 09-03-2007 17:37:19
You have an 80 3R mower. Sickle Service has complete sickle assemblies or Ford sections are the same as AC
Bill Crofutt
09-04-2007 20:01:38
 Thanks for the help! in reply to Tradititonal Farmer, 09-03-2007 19:10:40
Bill
Bill Crofutt
09-01-2007 21:50:34
I'll take a picture and post it tomorrow. It mounts on the 3-pt and has a spring loaded break-away system. Also has the gearbox that moves the knives back and forth. Thanks for any help!
