timing on D17
Bill- Kansas
08-31-2007 10:39:42
On a 1959 D17, we time by the pin in the flywheel. Will the pin go in the timinghole on exhaust stroke? Tractor runs but lost power, knocks, and smokes until warm. hard to start.
El Toro
08-31-2007 16:41:26
 Re: timing on D17 in reply to Bill- Kansas, 08-31-2007 10:39:42
You usually time an engine to No1 piston on the compression stroke, thats when your mag or distributor fires and you get that power. You probably need to check your engine to see if something has jumped time. Bring No1 piston to TDC on the compression stroke and then remove the cap on the mag or distributor and see where the rotor is pointing. It should be at the No1 plug tower. Hal
PS: When No1 piston is at TDC both valves on that cylinder should be closed.
