Starting a B
Dave 39B
08-29-2007 14:51:21
Hey guys,just bought a 39 B the other day.Today I went through the carb.and drained the old gas out and cleaned the points.Hooked it up to the truck and went to pull start it,only pulled her about three feet and she jumped to life.Drove around a bit and tried all the gears and the pto,she worked great and purrs like a kitten.I shut her off and crank started it a couple of times,started a little hard(8 or 9 cranks
)for being warm so I put in new plugs.Tried to start her cold and got some pops and kicked back a couple fo times,checked to make sure the wires were right and tried some more cranks but I finally quit.Are there any tricks to starting these or should I go through the mag and put in points and condenser.Any ideas or help would be very welcome.
Thanks
Dave
DS Mi
09-02-2007 07:53:03
 Re: Starting a B in reply to Dave 39B, 08-29-2007 14:51:21
sometimes we forget the simple thigs. make sure you have the throtle in the sweet spot. if throtle is all the way back, it might not start by hand my 2 cents. DSmi
Butch(OH)
08-30-2007 05:32:46
With everything in good order and properly choked a B or C will start in 2-3 pulls cold. Realize that "proper" choking is an individual tractor thing, ususaly 1-2 choked then off however we owned one that needed no choke cold or not. When it starts easy remember how you did it. They will usualy start in a pull or two when warm. I have never owned nor personaly seen a crank start model B or C allis that would easily start whem hot such as killing it under load, pull start or let cool down. Crank kicking is not a design flaw and should not be considered "normal". To kick the hand crank backwards spark must occur before TDC and it should not be that way if things are right in the mag and it is timed correctly. This is covered in the service manuals. An easy field check is to make double sure that the impulse is not clicking before the TDC mark is centered in the timing window. If not and you dont have cross firing due to a bad cap the crank cant kick, period. A battery ignition equipped B is a differant animal. I would NEVER hand crank one due to the fact that they have lots of static advance (fires before TDC at cranking speeds).
Dick L
08-30-2007 07:24:04
 Re: Starting a B in reply to Butch(OH), 08-30-2007 05:32:46
If the impulse dogs are wore just right they can release the spring to soon and fire. The timing can be correct and with the above happening it can and will fire early. When the impulse releases/clicks the rotor is some what free wheeling and will fire. What I gathered from the explainations is that by not noticing the click that the dog only cought some times and then he would get a spark then without the dogs catching there was no and can not be spark.
Dave 39 B
08-29-2007 18:55:03
Thanks guys,I probably will have AIS go through it for me.I like doing things for myself but the first time I play with a mag I'll use one I don't need just in case I screw it up.Oh ya Old it hit me pretty good,I had my thumb out of the way but it came around before I got my hand clear and smacked the back of my hand.Won't be doin much heavy werk with my right hand fer a while.
Thanks again
Dave
Sid
08-29-2007 20:34:53
 Re: Starting a B in reply to Dave 39 B, 08-29-2007 18:55:03
How I crank a tractor. Based on different manuals and what a mechanic taught me when I was a young know it all whippersnapper. Hold crank in left hand(do not wrap thumb around handle). Stand whith left hand on crank and pushing away from tractor with right hand. (You are facing across the front of tractor not facing the tractor.) Pulling up and over. If the tractors kicks back it will pull the crank out of your hand, and your right hand will push you back away from the spinnig crank. If you pull up and over with right hand the crank can spin back and get the back side of your hand. I have seen it done. I ain't saying you gotta do it my way, just saying that this is what I believe to be the safest way.
old
08-29-2007 18:58:32
By the way if you need a manual for that mag I have it on my computer and can send it to you if you send me an e-mail
old
08-29-2007 16:35:06
I agree with Dick on this plus impluse not working like it should can also lead to a broken arm. Of course being a little out of time can also lead to a broken arm. I had a B get me once and I went to the hospital because of it and yes I was holding the crank the right way but it still got me
DaVE 39b
08-29-2007 15:42:00
Forgot to mention this in my last reply,really nice page on mag timing Dick,I made sure to print it out and put it in my 39 B file.Great info there.Thanks
Dave
Dick L
08-29-2007 17:29:41
 That was Rod (NH) in reply to DaVE 39b, 08-29-2007 15:42:00
That was Rod(NH) that did the wonderful job on the magneto explanations, illistrations, and pictures. He has done a bunch of work like that on many Allis subjects.
Dave 39B
08-29-2007 15:35:20
Dick you might be on to something because I haven't heard the mag click when cranking even when I had the plugs out.I have other mag fired engines and they all make the telltale click.If this is the problem what do I need to do to the mag,a good cleaning or will I need some parts.Thanks again
Dave
Dick L
08-29-2007 17:38:42
 Re: Starting a B in reply to Dave 39B, 08-29-2007 15:35:20
The impulse drive would have to be disassembled and each part inspected to know if or what parts would be needed. Could even be a broken clock spring. I have repaired the dogs when the corners are rounded off. I bought in the neighbor hood of 20 magnetos at auctions and over Ebay over the years to have cheap parts. You should get a magneto manual if you have never rebuilt one and plan on giving it a try.
Dick L
08-29-2007 15:21:36
Try pulling it again. If it starts up in about three feet again my guess would be the impulse dogs are wore or one stuck. When you pull it the mag turns fast enough that the impulse dogs not catch to load up the spring. To crank start they have to catch and tighten the clock spring and when it clicks the spring spins the armature to build electricity for the spark.
