WD30 things to look for
SGF
08-27-2007 10:30:37
I just bought a 1964 WD40. It was bought to be a temporary replacement for a tractor that blew the engine. I have no background with Allis Chalmers. It will be used by people of varying experience so we have to get it reliable.
It was used until a year ago by the seller�s husband, and she said it ran fine when parked. We put a battery and fresh gas in it. It would fire but not start. When I shoot starting fluid in the carb intake it will run until I stop spraying. Fuel gets to the carb fine. My feeling is there may be some gunk in the carb"s fuel inlet.
My question is, is there anything in particular to look for on this model? We will change fluids. The points look good and fire fine. Any advice or hints would be appreciated.
SGF
09-03-2007 17:27:12
 Re: WD30 things to look for in reply to SGF, 08-27-2007 10:30:37
Just wanted to say the tractor running. All it took was some carb cleaning. There are some other things to get straight but the first big step was successful.
SGF
08-29-2007 09:31:44
The owner's manual has the serial number writen in it. It is lower than 160385 so if my research is right, it is a 1952 model, the first year the W45's were made.
SGF
08-29-2007 03:17:24
 Update in reply to SGF, 08-27-2007 10:30:37
We got the tractor to its new home last night after 9 PM. I haven't had a chance to search for the model number yet but I'm now pretty sure I know what it is. I don't know what possessed me to write down WD 30 because both sides of the hood have decal saying WD45. Based on the input I've received here that clearly means it is not a 1964. Now I have to find out what it is.
I am going to try and get some decent pictures to post, hoping that will help ID the year. If I find the model number that should clear it up.
Regarding the starting, as per my original email, �gas is getting to the carb�. I am going to shoot some carburetor cleaner in it tonight. I�m considering running a piece of wire into the carbs fuel inlet to ensure it is clear of trash. Before I do that I need to make sure there is nothing inside that I will damage by doing so.
I got theW45 manual with the tractor. I plan to see if I can decipher the fluid recommendations from old to modern. I know the owner made some notes but those questions, if any, are for another post.
Thanks for the replies so far.
farm it all
08-29-2007 00:33:26
Imay be wrong but sometime the simple things cause problems .Did you check to see if the tractor has a gas shut off valve ONtank or line ?as for model i think all ed40 uk were disel
Jack a
08-28-2007 04:52:34
Maybe it's an ED-40. They made not too many. Built in the UK in the 1960's.
SGF
08-27-2007 17:27:28
Okay, consider me sufficiently and deservedly beat up.
I'm sure of the year I was told but apparently I wrote down the wrong model. I always try to be accurate when I post but as you already know, I clearly blew it this time.
We go to pick the tractor up tomorrow so I will hopefully get myself straight on what model it is.
As far as the gas goes it is a carb problem as I get a good flow from the fuel line. Once I get the model straight I'd still be interested in particular things to look for. What I mean is, for example, the 73 to ? body style chevy trucks had a big problem with the hood springs being stronger than the hood supports. Bent hoods were very common. That's the kind of thing I'm talking about, model quirks and weaknesses. My goal is to eliminate potential problems in advance. Course having the correct model might help! I do know it is a row crop (tricycle front) though. That I'm sue of! Seriously, sorry for the confusion.
old
08-27-2007 21:39:21
 Re: WD30 things to look for in reply to SGF, 08-27-2007 17:27:28
Its easy to get the model wrong and a good number of people selling a tractor have no clue as to what they have just what others have told them. Shoot last year I went to a show and sitting there was a Allis tractor with a sign saying it was a WD45 and the year that it was. Both the year and the model was wrong. It was a WD tractor but the guy was 100% sure it was a WD45 but it had the stright shifter and the bolt on plate on the side of the engine making it a WD. So don't feel bad even people that think they know what they have often don't know what they really have. Thats why I said look in my web site and maybe that would help you figure out what it is
cadet trooper
08-27-2007 15:30:13
I'm thinking SGF is from England or Europe because I think I've seen a post a few months ago about these tractors and they might be similar to the D series tractors and was marketed in Europe. Regardless as John said it doesn't matter engine problems are universal whether it's in Iraq or Missouri you have to have what it takes to fire off a gasoline engine. CT
ACEd
08-27-2007 14:53:09
If it sat for a while I would look for crud in fuel system - as said above start at the carb, but also look at the whole system from bottom of tank to carb
1. it may have sediment in bottom of tank obstructing flow, or 2. maybe sediment bowl under tank is plugged up, or 3. maybe someone added a more modern in-line filter which may be plugged up (I just had that happen and new filter plugged almost immediately due to crud in tank that shook loose), or
4. some carbs have a screen at the inlet that could be plugged up, or
5. it could be inside carb - float or valve controlled by float
Pretty much all of these could apply if its an AC made from 1940-1970, but it would be nice to identify what you have - the only WD40 tractor was a 1930"s vintage International Harvester diesel - it was an odd bird and very unlikely you have one.
old
08-27-2007 12:33:47
First off it would be nice if you can post a picture in the help I.D so we can tell you what you have since they never made what you say you have. Now as far as your problem. Look at the bottom of the carb. There should be a drain plug there. Remove it and see if you get a good steady flow of gas. If you don't then you either have a stuck float or a clogged fuel system. You cn try tapping on the side of the carb with the drain plug out and the fuel turned on and see if that gets the fuel flowing. Look in my web page theres a few pictures of a WD and a WD45 plus a WC speed patrol maybe that will help you figure out what you have. And yes the WD and the WD45 are 2 different models
JMS/MN
08-27-2007 12:00:53
It would be nice to be able to buy WD40 made in the 60s. The formula they used then was a lot more potent- you could use if for starting fluid. Now, it's been watered down due to environmental regulations, until it's not worth much more than skunk urine. Used to be a good product. LOL
John (MO)
08-27-2007 11:20:04
Allis chalmers made a model WD from 1948 to 1953 and a model WD45 from 1953 to 1957. There is no such thing as a WD30 or WD40. In 1964 Allis Chalmers was making the D series of tractors: D10, D12, D15, D17, D19 and D21
Regardless of what tractor you have, it sounds like you have a carb problem.
