WD not running good
WD_Fan07
08-23-2007 20:07:29
my WD has run great for years. just last week it started popping and misfiring a bit after running at full throttle for a few minutes, then would continue after idling down. I put all new wiring, points, condenser, cap, plug wires, plugs, cutout, switches, lights, ammeter this year and rebuilt the carb. ran ok after putting wires on, rebuilt the carb after the trouble started. drained the gas several times and rinsed out tank with alcohol. now with fresh gas it barely runs and dies if I give it the gas, sounds like it"s running on two or three cylinders. it is battery ignition and the battery is 6 years old and is dead right now have to crank it. can a bad battery cause all this trouble?
Will Herring
08-26-2007 08:04:48
 Re: WD not running good in reply to WD_Fan07, 08-23-2007 20:07:29
Check your spark plugs, and see if they're getting any sort of buildup on them already.
Jimmy in Whitsett
08-26-2007 05:58:51
I read your post. Have you had battery load tested? If you haven't,first charge your battery up then if you have a d-c volt meter put leads on post try starting your tractor. If voltage spikes up 4to 8 volts you have shorted cell or plates in battery have lost their lead. Also had this problem like yours too. Converted to 12 volt system.
Also could be trash in carb & have you checked bowl filter under gas tank. my old W-D 45"s previous owner had soldered a 1" pipe onto it so sediment wouldn't get into fuel system as fast. Good idea unless you ran low on gas. Jimmy
Jimmy in Whisett
08-26-2007 06:14:29
 Re: WD not running good in reply to Jimmy in Whitsett, 08-26-2007 05:58:51
Ooopps!!! I didn,t read all the rplies like I should have I just jumped in. Sorry!!! Mr. Sid is right! Do a compression check. If you want too pull the valve cover off & check valves& springs at TDC. See if ones broke collasaped or if guide is worn out . Good luck on this. Jimmy
Sid
08-25-2007 10:03:20
Just for grins and giggles check compression. If you have a compression problem all the adjustments in the world won't make much difference.
WD_Fan07
08-25-2007 20:39:29
 Re: WD not running good in reply to Sid, 08-25-2007 10:03:20
that crossed my mind, when I have the air cleaner hose off I can hear funny chugging or huffing sounds out the carb when it starts or shuts off and when it idles down and wants to quit which it never made before
WD_Fan07
08-24-2007 21:15:39
now I charged the battery and it started but still ran funny unless I gave it almost full choke, then it ran fine. with choke off and about half throttle, it sounded like it was running on 2 cylinders yet, and it continued to run the same with the idle air adjusting screw all the way in! obviously getting way too much gas or not enough air, but I took the carb off again and checked it and the manifold flows good out all openings with compressed air. gonna start it tomorrow morning and see what she does...
old
08-24-2007 21:44:13
 Re: WD not running good in reply to WD_Fan07, 08-24-2007 21:15:39
Well to start off theres 2 adjustments on the carb. 1 is idle and the other is the mani jet. The idle one is up high on the crab and if you turn it all the way in you make it richer out makes it leaner. The lower jet is the main jet and that is the one you need to adjust for power and good running unless its at a very low idle. It works the other way around. In makes it lean and out rich, but if the carb is clogged some times it doesn't make a difference where the main is because its clogged up
WD_Fan07
08-24-2007 21:53:42
 Re: WD not running good in reply to old, 08-24-2007 21:44:13
yes it was the idle screw I had in, it usually starts sputtering when I turn it in but it didn't make a difference this time
old
08-24-2007 21:59:55
 Re: WD not running good in reply to WD_Fan07, 08-24-2007 21:53:42
A few things you can try before you rebuild the carb is. Take out the drain plug from the bottom of the carb and then take out each adjustment screw one at a time and spray carb cleaner in each. The reinstall each of them. Idle at about 1 turn out from bottom and main jet about 2 turns out and see if that helps. By haveing the drain plug out you wash out the dirt and it drops out the bottom of the carb instead of saying in a nd clogging it up again
WD_Fan07
08-24-2007 22:04:32
 Re: WD not running good in reply to old, 08-24-2007 21:59:55
way ahead of you, old. the carb has been scoured and rebuilt already, that makes it all the more puzzling!
old
08-25-2007 09:25:38
 Re: WD not running good in reply to WD_Fan07, 08-24-2007 22:04:32
That just means you or who ever rebuilt it missed some thing in the carb then. Its easy to miss a small piece of dirt in them and if you do then you will still have problems. BTDT many times and some times it take 2 or 3 tries to get a carb right even as simple as they are
Texas Denny
08-24-2007 08:56:13
I'm surprised you can get it to run at all with a bad battery. Your ignition lives off of the battery. If you have an alternator, it should never start as it needs voltage from the battery top start the alternator. If it has a generator, it might start and run if the generator is working well but only if you pull start - can't crank the engine fast enough to get the generator to work. With what you say, I'd guess the battery is poor and can't turn over the engine but it isn't completely dead. Try a good battery and report back.
old
08-23-2007 20:40:39
Depends on if it has a mag or a distubutor. If it has a battery type ignition yes and bad/weak battery can cause that type of problem
WD_Fan07
08-23-2007 20:42:36
 Re: WD not running good in reply to old, 08-23-2007 20:40:39
yes it has distributor it was converted long ago from magneto
