WD45 power steering unit
mark
08-22-2007 16:03:52
Folks,
I have a friend with a '56 WD45 and the power steering unit that goes on the steering column has locked up. He removed it and cannot get it apart. Having never personally seen such a critter, I don't fully know what it looks like, except by his verbal description. Apparently, the steering column runs through this gizmo (which he says is quite heavy) and it is fed by 2 hydraulic lines. He says inside, it looks like 2 gears and there is a spring loaded piston held by 2 circlips. The piston came out easy enough...but he can't get the rest of the unit apart to see what has locked it up. He was mowing when this happened...and the steering wheel was locked dead ahead and refused to turn.
So there..that is all I know, but thought maybe somebody would have a suggestion. I understand that this is an AC factory PS unit.
mark
08-22-2007 17:24:29
 Re: WD45 power steering unit in reply to mark, 08-22-2007 16:03:52
I just got an email from my pal...he got it apart and it seems to be an easy fix.
