My Guess Would Be
Dick L
08-21-2007 19:29:31
That it would be a shifting fork problem. You will have to drain out the oil and take the side plate off. To move it to a better place you most likely can slide the gears to where the forks line up and drive it to where you can repair the forks. You should be able to see the problem with the side plate in your hands. You might have to go deeper if after you have it back together it then pops out of gear.
