Alternator bracket on Wd
Randy Reber
08-21-2007 12:11:35
I mounted a alternator on my WD but the radiator cover hits the alternator. Is there a special bracket to use or something? I used the shortest belt I could find & there is hardly any clearence between the alternator & the throttle linkage to move the alternator closer to the motor for clearence & it still might hit the radiator cover. The bracket I made is centered on the frame rail. Should it be off set towards the motor?
stu (ON)
08-22-2007 15:12:28
 Re: Alternator bracket on Wd in reply to Randy Reber, 08-21-2007 12:11:35
If you want to spend some money on it, follow the www address back in the following link.
Will Herring
08-22-2007 14:43:22
Well uhhh... When we converted mine, we just mounted the alternator to the generator bracket. Used some all thread, bolted it in place, then moved the generator bracket forward about 3 inches and drilled new holes in the frame, and all is well. I wasn't gung-ho to drill holes in the frame, but this is a permanent change, so I finally decided it was the best way to go. I think I used one thick washer to shim up the alternator just a bit.
David Grubb
08-22-2007 08:06:04
Some guys cut the curved section of the shell off and that lets the alternator swing out to the left more; it also makes a sloppy looking tractor. I installed shims between the mount bracket and frame rail to raise the alternator enough to allow some outward adjustment without hitting the shell.
Randy Reber
08-22-2007 09:18:30
 Re: Alternator bracket on Wd in reply to David Grubb, 08-22-2007 08:06:04
Thanks, I will give that a try.
El Toro
08-23-2007 16:41:09
 Re: Alternator bracket on Wd in reply to Randy Reber, 08-22-2007 09:18:30
You can use a Hitachi alternator from NAPA that's smaller in size. Their part number is 2138130.
Cost about $50.00. Hal
