HD6B CRAWLER HAS NO POWER TO TRACK
Steve2
08-21-2007 01:08:03
My ol' girl has lost power to one of her tracks...so it now does a fine job of going in circles...the left track still functions, and if I pull back on the steering lever on that side then I have no power to anything and she stops dead in the water...anybody have a place for me to at least start? Thanks!
hector gemme
08-21-2007 03:16:13
 Re: HD6B CRAWLER HAS NO POWER TO TRACK in reply to Steve2, 08-21-2007 01:08:03
if water and dirt came by the hole stering cluch drain you will to clain the stering cluch compartiment and check your stering cluch adjustement and you need 3 inch free travell at the top of the stering level and check your brake you need 1 3/4 to 2 inch free play on brake pedal,let me know.
Steve2
08-21-2007 07:03:41
 Re: HD6B CRAWLER HAS NO POWER TO TRACK in reply to hector gemme, 08-21-2007 03:16:13
Thanks Hector...don't think that that's the problem, but plan to look in the compartment today. I'll check the play also just in case. It just went all of a sudden with no warning. Even if something is wrong with the brake or clutch would you loose complete power to that track? There is no drive there whatsoever. It's free movin', but just going along for the ride...
hector gemme
08-21-2007 10:23:32
 Re: HD6B CRAWLER HAS NO POWER TO TRACK in reply to Steve2, 08-21-2007 07:03:41
HI If the you have fiber disc stering cluch maybe the teeth are gone.
hectorgemme
08-21-2007 09:52:38
if he had a broken pinion or sprocket shaft the dozer just turned
