oil pressure
kendak
08-20-2007 06:19:20
Wd-45 I bought has't run in [10] years...has good compression {110psi),turns over, no noise that I can hear,full of antifreeze ,no water in oil, cam is turning [pulled valve cover]but has NO oil pressure...trying to get pressure up before starting using starter....thanks for any help or ideas...Kent
Harry J. Case
08-24-2007 19:29:33
 Re: oil pressure in reply to kendak, 08-20-2007 06:19:20
Hey kandak If you aren't getting oil up to the filter go ahead and drop the pan, either the pickup screen is clogged with sludge or there is a problem with the pump. I had this same problem on one of me WCs, the screen was just clogged up, pulled the pump out and cleaned it and the screen and had good pressure and flow. Good luck, Harry
kendak
08-20-2007 13:18:50
Sorry I was'nt too clear this morning but I have taken the main fitting out of side of block & get no FLOW from oil galley...service manual says that oil splits here & goes to filter & rocker arms..12V battery spins it pretty good with plugs out...it should have primed by now...I have seen in the past on other tractors the roll pin holding oil drive gear to shaft sheared off...didn't know if there was a common problem with the WD-45 pumps or what..thanks ..Kent
old
08-20-2007 08:29:08
In correct oil filter and or the tube that should be in the oil filter housing is gone either one will cause that problem. Or the oil pump has lost it prime and that will do it also
Tramway Guy
08-20-2007 07:01:17
If it isn't running, it won't have oil pressure!
Seriously, I would say that it doesn't matter whether you are turning it by pulling it with another tractor or running it on its own as far as potential damage goes.
But I would disconnect the oil line that runs up to the rockers and see if you are getting oil flow. That is much more important that pressure. Once you establish that you have flow, you can work on the pressure aspect.
Just having the wrong oil filter on it can cause little or no oil pressure [on the gauge].
Check the oil flow, and if that works, go ahead and run it. Then get back to us.
You might also search the topic "Oil filter" in the Allis section of this forum and you will find plenty of discussion on the subject.
