WD 45 Allis Transmission jumps out of gear
Raymond Miller
08-19-2007 13:42:00
My friend has a Allis Chalmers WD45 and the transmission Jumps out of gear can some one tell me how to correct this problem.
John (MO)
08-19-2007 16:36:22
 Re: WD 45 Allis Transmission jumps out of gear in reply to Raymond Miller, 08-19-2007 13:42:00
It could be that the shifter and forks are worn or bent an little and not letting the gears fully engage. Or, it could be the gears are worn because people have tried to shift it on the go or with the hand clutch. If you have to replace gears, the tractor has be split and the gears are expensive. If it is the shifter and forks the job isn`t nearly as difficult or expensive.
Raymond Miller
08-20-2007 13:55:09
 Re: WD 45 Allis Transmission jumps out of gear in reply to John (MO), 08-19-2007 16:36:22
Thanks John
