C Allis steering wobble
Blue Horse
08-18-2007 17:46:44
Just bought a 1946 "C" tricycle, and drove it home yesterday. It ran well, but has a decided front wheel wobble in road gear. What generally needs to be replaced in this situation? Also, how can I tell what decals to get for this tractor? Looking at the Central Tractor Parts catalog from Des Moines, apparently they make decals with black lettering, and blue lettering. (The existing decals are faded so badly that I can't tell which was used).
Blue Horse
08-19-2007 10:13:14
 Re: C Allis steering wobble in reply to Blue Horse, 08-18-2007 17:46:44
Thanks for the advice, everyone. Are new bearings readily available from AGCO dealers for these older AC tractors?
jk
08-19-2007 09:58:23
do you have an owners or an I&T manual for it? there shoul be a exploded view of the front end. theres a bearing in the pedstal thats worn out. my '42 C does the same thing, but i'm swapping mine to a wide front axle, so i'm not going to fix mine.
SteveJelf,SoKS
08-19-2007 06:39:46
Here's a reply I got last year when I asked about a drag link with worn out rubber:
I have used 3M Window-weld super fast urethane calk/adhesive. It's used to install windshields and you can get it at auto parts stores. I used it on tie-rod ends and drag link and it has held up for a couple years. I drilled a 1/4 inch hole in the back side of the joint and injected the stuff until it oozed out around the stud. Let it cure a few days and trim off the excess.
If the steering gear is worn out, it may be easier to find a good used one than to fix a loose one.
Allis nut
08-18-2007 22:37:14
As far as my books say the decals should be blue up to 1948. This is from Terry Deans Allis Chalmers farm tractors and crawlers data book. Hope this helps.
Ted inN NE OH
08-18-2007 19:25:10
Jack up the front of the tractor so front wheels off ground. Then start wiggling things to see where the play is. Couls be wheel bearings, front gear box , rear gear box. Either may need rebuilt. Shims can be removed from front gear box. A set screw (behind starter) can be tightened to help rear gear box. Past that it is bushings and bearings that need replacement
