WD 45 with wide front end
Randy Reber
08-17-2007 13:08:06
What is a WD 45 with a wide front end worth? All I know is the motor is stuck & it's pretty rough & needs tires.
David Maddux
08-19-2007 05:58:52
 Re: WD 45 with wide front end in reply to Randy Reber, 08-17-2007 13:08:06
Where are you guys finding wide fronts for 300.00? Most I see sell are for at least 500.00.
old
08-17-2007 13:19:53
I buy tractors in that condition all the time for $100-500. The wide front is a plus but the bad tires and locked up engine a minus. I would say around $250-300 for one like that but all depends on how much the person wants for it and how much your willing to spend
Randy reber
08-17-2007 13:26:36
 Re: WD 45 with wide front end in reply to old, 08-17-2007 13:19:53
Thanks, he wants $500 for it so I will have to take a close look at it. I would like to have it just for the wide front end to put on my WD.
old
08-17-2007 13:41:58
 Re: WD 45 with wide front end in reply to Randy reber, 08-17-2007 13:26:36
You might be able to talk him down is you have the green in hand. If you can't then oh well just the wide fronts sell for $200-400 depending on which one it is and how good it is. So either way even if you pay $500 for it you should be able to make your $$ back just by selling a few parts off of it. Or if you fill the cylinders with tranny fluid and just keep doing that for a month or so you maybe able to get it to run again. BTDT many times
John (MO)
08-17-2007 13:17:23
Well as a parts tractor the WF is worth about $300. Don`t sound like there is much else there with a lot of value. You might get lucky and find the motor and transmission don`t need a lot, after you tear into her... BUT you might get unlucky and need motor guts and gears too. I'd say $500 to $600 is top dollar, not knowing what you don`t know.
John (MO)
08-17-2007 13:17:15
