200 Allis overcharging batteries
NorthM
08-17-2007 07:25:08
Tractor would not start the other day with batteries only a year old. Discovered the batteries were bone dry and tops popped on the batteries. Filled with water but one will not take a charge. Is there anything else I can do. How do you set the alternator to keep it from overcharging. Thanks
El Toro
08-17-2007 07:59:10
 Re: 200 Allis overcharging batteries in reply to NorthM, 08-17-2007 07:25:08
Your regulator is what keeps your charging voltage
from over charging. This may have ruined that battery that won't accept a charge. You probably need to have it checked at your local shop.
Your alternator and regulator should be checked
at your local shop that repairs alternators, starters and generators. Be sure to remove the battery ground before removing the alternator and mark all your wiring. If that alternator has an internal regulator you may be better off to get a rebuilt alternator. Hal
