262 engine
mEl
08-17-2007 04:44:37
Is anyone familiar with head gasket irregularities in the 262 engine,one with the water pump in the head,the gaskets hang over the intake pocket and fail, just between i believe 2-3 and 4-5 where the head is narrower than the other cylinders, is there a manufacturer who supplies a gasket that will sit further out on the head away from the pocket.The engine has other issues, the ex valves were hitting the piston tops slightly and if anyone has info having,to do with ex valve + or minus from head surface, min head thickness, i would appreciate your help. The deck needs flattened and the sleeves reset as they show recession on two cylinders. can this be done without milling the piston tops. I need all these specs. Thanks in advance, mEl
