Serial Number wd45
Harlen Larson
08-16-2007 18:03:28
A friend of mine bought a tractor sight unseen and had it delivered to me to do some work on it. Supposedly a wd45. I'm kind of thinking wd only. Where is the serial number located? It has a curved shifter but it has a plate that bolts to the right side of the engine under the head the full length of the block. Is this the plate to look for?
Harlen Larson
08-16-2007 18:51:53
 Re: Serial Number wd45 in reply to Harlen Larson, 08-16-2007 18:03:28
#192573 1955 WD45 AS to what has been done inside I haven't a clue. Thanks for the info.
old
08-16-2007 19:42:32
 Re: Serial Number wd45 in reply to Harlen Larson, 08-16-2007 18:51:53
Sounds like its a mutt tractor. I.E. one that was made from 2 or more. It does in fact have a WD block in it but of course it could have WD45 parts in it but its still a WD block either way.
02XLT4X4
08-16-2007 18:41:07
The question of the day is what was done inside. He could have a late WD with the syncromesh tranny as a WD-45, a WD-45 with WD engine internals or a WD-45 with a WD block and WD-45 engine internals. If you have the plate there is no garentee as to what is inside.
WD/WD-45 Serial #'s are on the left side of the rear differential, just to the right of where the lift arm mounts.
