Installing new battery
cchrist214
08-15-2007 18:01:35
Trying to install a new battery in my dads old D17 as I remember from my youth this is a positive ground system. So I assume that that I just hook the battery with the positive terminal to the ground. Second part of the question if I need to jump start this thing or charge the battery do I hook the charger up positive to positive or do I reverse the cables?
Flewster
08-21-2007 08:00:40
 Re: Installing new battery in reply to cchrist214, 08-15-2007 18:01:35
What are the advantages of a positive ground over a negative ground..... .I guess my real question is why a positive ground?
JMS/MN
08-15-2007 18:08:53
The D17 is a positive ground system. Hook up the negative cable first, positive ground last. Polarize the generator. When charging ANY battery, always POS to POS, Neg to NEG.
Jim McDonald
11-07-2007 11:33:01
 Re: Installing new battery in reply to JMS/MN, 08-15-2007 18:08:53
Maybe I should have asked: How do you polarize the generator? Does hooking the battery up negative first and positive last automatically polarize the generator on a positive grounded system, or do you have to do something else like jumper the voltage regulator battery terminal to the voltage regulator generator terminal?
Jim McDonald
11-06-2007 10:05:31
How do you polarize the battery? I am having trouble with my D-17 not charging. I have replaced the voltage regulator twice, and had the generator rebuilt.
