WD hydraulics
Micheal
10-19-1999 08:42:55
As the new owner of a WD, I would like to know if the hydraulics for the two-pt will run a remote cylinder and where that remote coupler should be plumbed in at? I have heard that the WD hyd are High pressure/low volume and that you can't run a regular cylinder off of them. That you need a hi pressure cylinder for your remote cylinder.
anyone have any advice on this that you would be willing to share.
Thank you in advance.
micheal
bentorbroke
10-19-1999 17:49:34
 Re: WD hydraulics in reply to Micheal, 10-19-1999 08:42:55
The WD hyd sys operates at high pressure (about 3200 psi) and usually operates rams vs. cylinders. The rams are one way only. It can operate one way cyl's if they are rated for the pressure. Usually you will want a correspondingly smaller cylinder for this pressure (or you will over load, bend, break, or otherwise damage something). A 2" dia. cyl on this system will generate a lot of force. The sys. will operate a two way cyl only if you add a seperate valve (4 way) to control the two way cyl. The remote (one way) cyl is usually hooked up to the port on the left side of the hyd valve across from the hyd line hooked to the right lift arm ram and next to the line that is hooked to the left lift arm ram. Be sure to use 4000 psi rated hose (3/8" is OK) and use a Break-Away connector. Hope this helps, bentorbroke
Micheal
10-20-1999 06:38:31
 Re: Re: WD hydraulics in reply to bentorbroke, 10-19-1999 17:49:34
Thank you, very much, that is the info I was looking for!
micheal
