cleaning an oil bath filter
WD_Fan07
08-12-2007 12:25:37
is there any way to clean out the mesh inside the can? i have regularly cleaned the cup but the mesh is full of junk. can i pull it out or is it non-removable?
D13
08-14-2007 06:50:50
 Re: cleaning an oil bath filter in reply to WD_Fan07, 08-12-2007 12:25:37
Depends on the gunk. If it's oil and dirt, soak in kero, diesel, mineral spirits, and then use brake cleaner to finish. If it's got grass in it (like my laen mowing B) then hot tank or fill with oven clenaer and put in garbage bag for a week. then use the brake cleaner when the chunks come out. Less than $20 to hot tank if someone has one nearby, or a 5 gal bucket and $5 of lye at Kroger.
Will Herring
08-13-2007 16:03:10
It's a handy way to use up old gas that just doesn't seem to be doing the job anymore.
Matt L
08-13-2007 13:16:33
I always hot tank all the oil bath stuff on all my tractors. Makes the inside look like new. third party image
Phill Snartland
08-13-2007 10:56:26
On my WD-45, there is a snap ring at the bottom of the filter housing. This lets the steel wool come out, I think.
JMS/MN
08-13-2007 07:55:36
Steam cleaner would be great, lacking that, hook a pressure washer to a hot water supply. Gets the grease out much better than cold water.
Kent of SWMO
08-12-2007 16:59:19
Hot tank at you local automotive machine shop. No disassembly required. Kent
Dick L
08-12-2007 15:22:23
You can back wash them with a parts washer if you have one.
Jerry Coulter
08-12-2007 15:08:00
We used to cut the welds and remove the mesh, unroll it and wash it. Then tightly roll it back up around a piece of pipe the right size or slightly larger, push it back into the body and spot weld the retainer.
old
08-12-2007 12:53:28
The way I have done it but now days costs a lot is to soak it in a bucket of gas.
